Mode-Mixity computation in 'Interface crack'
Hello everybody,
I am working on the the fracture analysis of a crack between 2 materials (interface cracks) in Ansys. I understand that mode mixity is a very critical parameter in interface cracks. There are a lot of methods proposed in the literature to determine mode mixity (using modified VCCT, complex SIF solutions, CSDEM). I am specifically into the one of the form in 'Hutchinson et al' refer (page 85 eqn 2.57) of the attachment and CSDEM, refer (page 6 eqn 6) of the CSDEM attachment. Each of these methods give a different mode mixity (psi) as shown in (Agrawal-Literature - Page 17 Fig.5 ).
I would like to know
  • If there is any criteria on the choice of the method to use? Like how can one justify choosing a method?
  • Also, I understand mode mixity intuitively, but how does one confirm that the mode mixity values (from FEM) are indeed correct. I could not find analytical solutions for complex 2D and 3D problems.
It would be great to hear from the learned.
Thanks in advance for your time.
Shree
P.S. I could not attach more than 1 file. So, please look into the following URL for the attachments. "https://www.researchgate.net/post/Mode-Mixity_comp..."
