Vertical Thermosyphon Reboiler Replacement
Hello, I am working on a project to replace a feed flash exchanger to a column. This exchanger will be increasing in surface area from 1000 ft2 to 1400 ft2. This exchanger is also used as a vertical thermosyphon reboiler during campaigns about one day per month when the tower processes a different feed to a different nozzle on the tower. The remainder of the time it is a once through feed flasher to the tower.
My question is: The increase in surface area and heat duty is only required for the predominant mode of operation (feed flasher) where we will be processing more feed. When we switch modes to use the exchanger as a thermosyphon reboiler, I want to ensure no issues arise. The elevation relative to the tower, liquid draw sump, liquid feed line, and reboiler return will not be changed, i.e the height of the exchanger will be the same and the increase in surface area will be accomplished by increasing shell diameter. The reboiler and outlet piping will be increasing in diameter. The feed required to the reboiler during this mode will be the same as it is today. The friction loss through the entire network will be decreasing, so I should still be able to process the same feed? Likely at a lower hot fluid mass flow.
Is there anything else I should be paying attention to with regard to ensuring the thermosyphon mode still works?
Thank you,
D
Thank you,
D
RE: Vertical Thermosyphon Reboiler Replacement
