Automatic Block/Tool Palette Updates
Geeks,
I'm looking into streamlining wiring diagram creation in Autocad using standard tool palettes. I'm looking into how easy it is to maintain these wiring diagrams over a product's life (Say a connector changes, etc.). Replace has worked well, but I'm trying to see if you can automatically update blocks on another drawing sheet should the block design change (adding a feature to it, etc.). If I update the block on the template the tool palette pulls from, how can I easily update the existing blocks on the drawings I'm using them in?
Aaron
Aaron
RE: Automatic Block/Tool Palette Updates
