Power screw + nut axial forces and torsional stress
Dear All,
I have a question related to using power screw. Power screw is used to convert torque into axial forces on the nut. The axial forces between the nut and power screw will be equal and opposite to each other and the applied torque on the screw is function in applied forces. My question does the applied torque translate also on the nut or just the axial forces. I mean the nut will be subjected to axial forces between the nut and the screw only or there will be also torque on the nut equal to the applied torque on the screw itself.
RE: Power screw + nut axial forces and torsional stress
