2004 Bystronic BySpeed 3015 4.4kW Power Requirements
Datasheet for 2004 Bystronic BySpeed 3015 4.4kW laser states that it uses 56kW for the overall system (resonator, chiller and dust collector) running at max. settings. This translates to approx. 70kVA with a 0.8 power factor. With that in mind, I have the following 2 questions:
1) What kind of kVA would we be looking at if we're primarily cutting .06-.09" (MS-1008 & ALU-5052-H32)?
2) What is the max. kVA could we pull from our existing 200A @ 240V 3P incoming power using a transformer? Notes: this will be the only major piece of equipment running on that panel. Current consistent load on the panel is around 40A and we can get it lowered by turning off some additional non-essential devices when using the laser.
Any help would be great! Thx
RE: 2004 Bystronic BySpeed 3015 4.4kW Power Requirements
Perhaps you can find a deal on a 2kW fiber laser? Power requirements would be much lower and it would do a great job cutting your materials
Chris Krug http://krugtech.com/
Maximum Up-time, Minimum BS
