Shell plate replacement.
Dear experts,
During construction a new tank, by mistake my subcontractor install the wrong shell plate (1 plate only) in the first course. All verticals have been completely welded.
We are not allowing them to erect the 2nd shell course till the wrong plate is replaced.
The correct plate is available. We have to cut the 2 verticals (V3 and V4), remove the wrong plate and insert the correct one. There would be 2- verticals welding on the same location (V3 and V4). The width of the shell is 2100 mm.
My concern is this V3 and V4 have been welded, flame cut and again re-weld.
Is there any restriction in API 650 or 653 in regards to the above issue
Syah
Syah
RE: Shell plate replacement.
Tank : 56 M dia. x 15 M Ht.
Material A516-Gr. 70(N). Thickness 8 mm.
The plate size is 2100 mm (W) x 11000 (L).
Design metal temp. 95 deg. C.
We just erected 1st shell course only. We could not erect 2nd course till this plate is replaced.
Syah
Yes, you are right. We are using jacking method. The first course here meaning top shell course.
The maximum liquid level by the design is not reaching this top shell course.
Thanks for your opinion.
If the plate is thicker than it needs to be, I'd leave it in.
If cutting on the seams is a concern, cut a section out just a little wider than the plate that was welded in.
Does flame-cut material require any special restrictions that mechanically sheared material does not? Not really; just grid to shiny metal prior to welding.
If you trim off the weld plus the HAZ [HAZ will be < 0.1mm], do you think that the remaining material 'remembers' being welded on? Not possible.
Thee is no 'problem', except in some folks minds; they are thinking 'Repair'. JStephen got it right - this is Rework. The problem is completely removed & the area will be returned to its original condition. Rework, not Repair.
Thanks for all your opinions.
The PMC welding inspector is concerning about the vertical joint of existing plates on the tank. The vertical on this plate had been welded then flame cut then weld again. So many heat input will be received by this plate on the vertical joint area.
This is really unfortunate situation. Because if we cut let say 100 mm beyond (both side) the existing verticals, we do not have extra length 200 mm on the correct shell plate.
If we are taking the risk by putting the correct plate, welded then client will request hardness test on HAZ area. If the hardness is not acceptable we have to cut again and buy a new material from overseas.
The PMC welding engineer shows me API 653 (we know this is not relevant since we are building new tank per API 650) that cut and re-weld on horizontal joint is acceptable.
This issue still being discussed. I will suggest to the management to take the risk maybe we are lucky I mean the hardness still acceptable.
Syah
