Compatibility With Excel
I was just curious of how easy it is to interface RISA 3D (or RISA Floor) with Excel for pre or post processing? We have run into several projects in the past where we either needed to define complex geometry using Excel or strip out results to post process using Excel. Is this an easy option in RISA, or would you really have to fight to make it work?
Thanks!
Thanks!
RE: Compatibility With Excel
Output spreadsheets can be copied and pasted into Excel as well. Though not all output is available, so you can only copy and paste what results are shown in the spreadsheets.
RISAFloor is similar, but probably a little trickier. Some of the input is more graphical in nature and is not directly controlled by spreadsheets.
To my mind copying and pasting (in either direction) is much easier and quicker than saving to a csv.
Doug Jenkins
Interactive Design Services
http://newtonexcelbach.wordpress.com/
