RS232 Cable Problems
For people who are using RS232 for Data transfer
Please stick to pin configuration when attaching the cable. 90% of the time, LSK error or DR signal off error comes due to improper soldering or wrong pin configuration.
25 pin on machine side and 9 pin on PC side.
I've attached the pin configuration for reference.
If data transfer is not occurring(LSK error)
1. Settings might be a problem: Check the software settings, Baud Rate Stop Bits, etc. It should match the machine parameters
2. Rs232 cable might be a problem: Always stick to pin configuration and check the cable for continuity.
3. Port problem on the machine side or PC side.: This happens very rarely but cannot be ruled out.
Also try using a USB to RS232 converter for better reliability.
RE: RS232 Cable Problems
USB to RS232 converters are fussy, look for converters that use the prolific chipset
Chris Krug http://krugtech.com/
Maximum Up-time, Minimum BS
IR, I initially had the same question... my guess is he was running into issues with the comms to his laser.
Dan - Owner
http://www.Hi-TecDesigns.com
@IRStuff many old laser machines use rs232 comm ports.
the older bystronics used 2 com ports. One for machine/human interface and the other for moving job data
