What Happened To SolidWorks In Version 2016?
Using SOLIDWORKS 2016 SP1.0;
Lots of features that worked well in previous versions don't work well or don't work at all in version 2016.
Other users having the same issues or is it my imagination?
Any response will be greatly appreciated!
RE: What Happened To SolidWorks In Version 2016?
Can you update to SP4.0 ?
Chris, CSWP
SolidWorks '16
ctophers home
SolidWorks Legion
As long as features are concerned I did not come across one that doesn't work anymore. On my part it's more about the new features that need a little tweaking. Unfortunately SolidWorks seems to rush the new features in and wait for the users to test them so it takes a couples of SP's before they get it right (If they ever...;)
If you can give me a couple of examples maybe I can test it and see if I have the same problem.
One thing I noticed though is that SolidWorks seems slower in general. I can't know for sure if it's because of 2016 or if it's Window 10 (I upgraded to Win 10 at the same time as I installed SW 2016) But I clearly saw a drop in performance.
Patrick
Scott Baugh, CSWP
FAQ731-376: Eng-Tips.com Forum PoliciesGryphon Environmental
www.2gryphon.com
Satisfied user - Diego
No one can tell you if their issues with SW 2016 are 'similar' to yours unless you tell them what your issues are.
I use SW approximately 40 hours a week, and have zero complaints about '16.
edit..I see that they brought back the color option. I think the company had SP1 installed.
There is no situation so bad that you cant make it worse. Cmdr_Hadfield
As for the colors I am glad they brought some of them back and they adjusted the contrast to be darker.
Scott Baugh, CSWP
www.2gryphon.com
