How do I output displacement at a point on rigid body?
Dear all,
In ANSYS Mechanical (not the APDL), can I output the displacement at a point (vertex) on a rigid body?
I tried User Defined Result which exported all displacements at all nodes. But because the rigid body is not meshed, there are no nodes nearby the point that I want to probe.
Any ideas?
Thank you!
Shawn
RE: How do I output displacement at a point on rigid body?
Did you tried placing Coordinate System? Then I think there is Probe Position option in results - so you assign body and coordinate system to it.
I am not sure if I understood you correctly, but if I did and you need displacement plot on a specific node, then do the following:
Choose the node, and create a named selection from it, then insert a "deformation" plot, in "scoping method" choose "named selection" and choose the named selecion containing that node.
Thank you marianw88 and assafwei! I made it work with a very similar method as you mentioned. Currently I used remote point to probe the displacement and force, as it is allowed to have remote points on rigid body; I never tried to use the coordinate system method and it sounds much better. I will definitely try it.
Thank you again!
Shanw
