Assistance needed: 90 degree vertical USB A Female Receptacle Left and Right help
I am trying to locate a MATCHING pair of 90 degree USB vertical USB A Female Receptacle in both left and right. We have a circuit board that we want the USBs that go into it to be back to back. Does anyone know of such a set? I have done some pretty extensive searches though have not had a lot of luck. Thank you in advance!
RE: Assistance needed: 90 degree vertical USB A Female Receptacle Left and Right help
I'm not sure what you mean by "left" and "right", however. Do you want the receptacles to be on opposite sides of the PCB, or on opposite ends? You say "90 degree" and "vertical", which to me are polar opposites... perhaps you mean "right angle" instead of 90 degree? A vertical receptacle (or "straight") would be perpendicular to the PCB surface.
Dan - Owner
http://www.Hi-TecDesigns.com
Presumably, they have something sticking out that would interfere if both receptacles were oriented the same.
TTFN (ta ta for now)
FAQ731-376: Eng-Tips.com Forum Policies forum1529: Translation Assistance for Engineers
Dan - Owner
