Regarding Edge blend
RE: Regarding Edge blend
You can use the Rib Top Face Edges in the Curve rule for selection. Select the face and all edges will be selected
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
HP Zbook15
Intel(R) Core(TM) i7-4800MQ
CPU @ 2.70 GHz Win7 64b
Nvidia K1100M 2048 MB DDR5
in this case you can also rotate the view such that you see the model from the side, set the selection to "single curve" and drag a rectangle over the edges to be selected. ( the multi select rule should be "inside".)
Tomas
Thank you Ronald and Tomas. :)
Isha
Mechanical Engineer
I do a trial selecting with the fillter "Rib Top Face Edges" and then return to
fillter "Single curve" and do a deselect of one of the pin edges to do blend all but one
but NX refuse to it
a984928 :
When you select using the "Rib Top Face Edges", this is a selection rule and not a selection filter.
The rule means that if the number of edges selected by the rule increases or decreases, it will be automatically selected/updated.
The "Single curve" is a selection filter and not a rule. If you have selected all 50 edges by the rectangle method I mention above, those 50 are the selected edges. If you would increase the pattern count the new edges will not be selected because the selection method was "single curve". Only the 50 edges will be blended. You can of course edit the blend and add the new edges manually, or change the selection method to a selection rule. (Right click one of the selected edges and change the selection method)
Tomas
Thank you Tomas
Its good to learn any thing any time
I forgotten to ask please
The rules and filters are in the same drop down
window how to distanguish between them
Connected curves
tangent curves and so on
Thanks in advanced
