The volume of 12424 elements is zero, small, pr negative.
I am getting this error massage: The volume of 12424 element is zero, small, or negatibe. Ckeck coordinates or node numbering, or modify the mesh seed. ... . The elements have been identified in element set ErrElemVolSmallNegZero.
How can i delete this elements using cae ?
Thanks !!
Thanks !!
RE: The volume of 12424 elements is zero, small, pr negative.
