Error on Getting Information Like Mass, Volume, etc
RE: Error on Getting Information Like Mass, Volume, etc
You most likely have a geometry error. Run the examine geometry command, set all the body and face checks, window select around your model and press the "examine geometry" button. If you get any body errors or face-face intersection errors, these will need to be fixed.
www.nxjournaling.com
THANKS,
