17-4 H1075 to H900 Condition
Hi Team,
Recently our customer request for 17-4 H900 part. We use material 17-4 H1075 & did solution annealed and HT to H900 condition.
Once we done annealing & HT to H900 Condition, will be the material yield strength and tensile strength as per H900 or different from H900 mechanical properties?
Please advise.
Thanks.
Please advise.
Thanks.
RE: 17-4 H1075 to H900 Condition
It should be H900, if you did everything correctly.
In the PH grades you get grain refinement with re-heattreating.
The other main fault is not cooling low enough and fast enough between anneal and age.
The HT process as below,
Base material 17-4 H1075, Required 17-4 H900...
Annealing @ 850°C for 2 Hours
Quenching @ 1020°C for 2.5 Hrs (Gas Cooling)
Tempering 1 @ 480°C for 3 Hrs & Tempering 2 @ 475°C for 3Hrs to achieve hardness Min 40HRC.
Please advise.
1900F +/-25F for 30 min (once temp is reached)
cool to below 90F within 1 hour
age 900F +/-10F for 4 hours
At 950 the limit is a bit over 2hrs, at higher temps you don't really want to go beyond 1hr or you will start reducing properties.
what is the need for 850C anneal? Also, why aging twice? I see no benefit from these two additional HT.
And I hadn't converted the anneal temp, I hope that the 850C was a typo because it won't work.
You can re-anneal and re-age these alloys over and over. You will loose a small amount of strength (compensate by lowering aging 25F) but the toughness should improve (as the grain size gets finer)
Your definition of the process, with the exception of certain testing protocols for load coupons, is in-line-with AMS2759/3.
NOTE, for aerospace: MIL-HDBK-1587 MATERIALS AND PROCESS REQUIREMNTS FOR AIR FORCE WEAPON SYSTEM, Table 1 Restricted Materials, indicates that 17-4PH HT to H900 and H925 [and sometimes H950] are generally prohibited... mostly due to poor SCC, low fracture toughness and possibly premature elevated temperature corrosion issues.
Regards, Wil Taylor
o Trust - But Verify!
o Unfortunately, in science what You 'believe' is irrelevant. ["Orion"]
o Learn the rules like a pro, so you can b
