CATIA termination
CATIA termination
Hi Folks,
I have an issue where CATIA terminates abruptly while rotating a part or while downloading a part from tce.Any reasons?
RE: CATIA termination
Did you look in abend report file?
Fernando
https://picasaweb.google.com/102257836106335725208 - Romania
https://picasaweb.google.com/103462806772634246699... - EU
I am attaching the same.
Forgot to insert in the previous post.Please find the same.
Fernando
Please find the abend trace file attached.Also do let me know what to check in that.
You are working with a CATIA release which is not supported anymore by DS and even more, you are working with an unsupported OS for that release. So, things like this can happen...you can report to DS but you will not get any answer from them.
Fernando
Thanks for your reply.Could you please tell me the supported OS versions for r18? we are using win7 here.
For Win 7 you have here
Fernando
It seems to be only about v6.I am uploading one more error log file here from the same user.Please do let me know if you have any clues on this.By the way the driver version is 347.52 ( NVDIA quadro 5000 ).
Fernando
Thanks for the quick reply.No,we did not try to open the file in a higher version.the user is trying to open the files in both local and from tce.the particular machine has been having the trouble for long in regards to CATIA termination.any thing with the hardware?
Fernando
I have the abend file.could any one please let me know how to figure out this termiantion issue?
open an SR and see what they say.
Thanks for your suggestions.But any clue from the abend file?
if other users on other computers don't have the problem, then it's not a CATIA problem.
if only 1 user has problem on several computers then it might be in user profile, temp files (or it's the user)...
if any user have problem on only 1 computer, then it might be computer setup or hardware. it might then just be faster/easier to reinstall OS or re image computer...
thanks for your answers.
Any idea why this issue might happen in several users ( not at the same time ) but in different instances.might be due to any windows updates in the server or any antivirus updates in the client machines? any ideas?
