Arc Flash on Direct Current Systems
Hello All,
The DC arc flash at the battery bank is high (above 40cal/cm2). I was wondering if anyone has a good reference on what is a good solution to work at the battery or how to make them more safe to work
RE: Arc Flash on Direct Current Systems
None of the attachments could be found. Could you repost the attachments? It would be of interest to know the battery specifics, make, model, number in bank.
