More than one BOM?
More than one BOM?
Running SW2013. I have one sub-assembly that appears in two different configurations, one of each, known as INBOARD and OUTBOARD, on a larger machine. The current documentation the maint. techs are used to working with was done in AutoCAD and has no BOM "intelligence" to it like SW does. The numerous changes over the years, done by different engineers at different times on different drawings, none of whom wanted to redraw the whole thing, have resulted in a situation where in order to completely rebuild one of these assemblies correctly the technician must consult several different drawings, ignoring some of the information on each, and always remember to consult with the last guy that touched it. I'm sure some of you can relate. I have decided to bite the bullet and redo the whole thing in Solidworks.
I would like to have one drawing that would show both configurations with a separate BOM for each. Can one drawing do that? Have more than on BOM?
RE: More than one BOM?
Patrick
Patrick
Steve R
