(World View Projection Matrix) Do someone know how to do this in vb nx journal
Hi
'I found this solution in the internet and I need it in vb nx journal
'This is done by multiplying the point with the WorldViewProjection matrix... i.e.
'WorldViewProjection Matrix = World Matrix * View Matrix * Projection Matrix
'2D Point = 3D Point * WorldViewProjectionMatrix
Thanks in advanced
RE: (World View Projection Matrix) Do someone know how to do this in vb nx journal
Projecting a point using matrix multiplication is just standard linear algebra. The text you quoted looks like it comes from an OpenGL document. That same document probably tells you how to do matrix multiplication.
None of this has any relationship to NX.
If you want a better answer, you'll probably have to clarify the question.
Hi BubbaK and I'm very thank you for waking up my post
my original problem wase in the following (my post with no response)
http://www.eng-tips.com/viewthread.cfm?qid=412477
and this is why I try this post
what I need is a way to clip a rectangular screen
The journal in the above link allwaise draw the rectangle in the xy WCS
and not on the screen
Thank you for the response
