Pattern of holes, different hole sizes, multiple single segment position tolerance
I have two hole patterns of two holes (4 holes total) called out separately because of their difference in size. It is critical that the 4 holes travel together as a pattern.
How do I properly emphasize that the two different hole callouts must travel together? I feel like this is some sort of simultaneous requirement, but I'm not sure how to do it.
I am also using a multiple single segment FCF because I have more tolerance in one direction than the other.
Please advise.
Please advise.
RE: Pattern of holes, different hole sizes, multiple single segment position tolerance
http://www.ttc-cogorno.com/Newsletters/130515MultP...
John-Paul Belanger
Geometric Learning Systems
John-Paul Belanger
