PWM vs. Linear Amplifier effect on motor efficiency and heat losses in motor coils
Hi
I have a question related to PWM vs. Linear Amplifier. I know the PWM amplifiers run cooler than standard linear power amplifiers and hence the PWM amplifiers has higher efficiency. I am wondering what about the motor itself. Are both PWM vs. Linear Amplifier produces the same heat losses on the motor?
RE: PWM vs. Linear Amplifier effect on motor efficiency and heat losses in motor coils
Gunnar Englund
www.gke.org
Linear amplifiers are real specialty items now, really only used in super-precision applications that cannot tolerate the vibration or EMI from a switching amp.
Curt Wilson
Omron Delta Tau
