Model not tied down
Model not tied down
Model not tied down
I am using Creo 3/Simulate. A model is made in third party
software of a 120" diameter pressure vessel consisting of
four 88" long cylinders with dished heads on the ends. It seems to
import into Creo ok but fails to run because the cylinders
won't connect to each other. How can I get the cylinders to
connect in the analysis? Is there some kind of tolerance
to set to that parts are properly connected?
