Selecting right pump for the job
I would like to install a submersible pump in my storm sewer pond (used to be a detention pond) so that I can outlet water to a county ditch. I have spoken with the county engineer and have been given the okay as long as I do not exceed a discharge rate of 0.2 cfs or 90 gpm. I would like to install an industrial model pump rather than a cheap one used in residential basements. I am currently looking at a HOMA TP28 (TP28V16/2/1) submersible pump but I am afraid that the discharge rate will be to high since my total head is only 5 feet. So my question is, how can incorporate an industrial pump with my pond drainage and meet the requirements of the county.
RE: Selecting right pump for the job
Install a valve on the pump discharge so that the pump may be throttled. Develop a method to measure the flow rate. Use a timer or a flow meter.
The HOMA brochure shows how the pump should be installed.
Google "submersible sump pump" and go through the results till you find what you are looking for.
I would say this pump is ideal - get the V2 version at with a total head generated of 5 feet, you have a discharge rate of 90 USGPM - Perfect.
If for some reason you end up with more friction losses or a small blockage, the head increases rapidly whilst the flow stays quite high, e.g. for 20 feet head you're still getting 60 GPM
