Problems creating non horizontal parallel lines
I am a recent Draftsight user and am struggling to create parallel lines at angles away from the horizontal x axis. I am looking to use these parallel lines to form construction lines to use for my drawing. I was able to create parallel lines using the ortho function, but this only works for lines in the x or y direction. Is there a way to use the parallel function for lines at an angle?
Currently I've been using trig to work out each coordinate, but this is very time consuming!
Any help would be massively appreciated.
Thanks!
Lisa
RE: Problems creating non horizontal parallel lines
Try using the "offset" command. It will ask you for a distance, select the line you want and the side you want to offset to. It will then place an exact copy of the line you selected on the side you chose at the distance you put in. It works great for any line. In fact it will even offset a circle or arc. I use it all the time.
Good luck,
Gary
Many thanks for your quick reply Gary.
I couldn't get the offset function to work with an infinite line, but it works with a standard line.
Thanks for your help :)
Lisa
Lisa, it works with an infinite line for me. Give it another try. At least you were able to get it to work on a standard length line.
Gary
I managed to get it to work thanks Gary.I was trying to offset a line with an infinite line, but realised you are only able to offset the original shape.
Thanks again.
