good vacuum gauge recommendation needed
Hi.
I am working in a small engineering company dealing with vacuum equipment used in process, power and other industries requiring vacuum. I am responsible for going out to field to tackle the ever so important issue of equipment not working according to design specifications. We have a case of measuring instruments, which i inherited (and still share) with the VP of engineering. As he is doing this for 25+ years , he is accustomed to a certain vacuum gauge, which he likes. I do not like it too much. We are using 2 types of gauges, both manufactured by Vacuubrand:
1- Vacuum gauge DVR 2 --> http://www.vacuubrand.com/us/page790.html
2- Vacuum gauge Set DCP 3000 + VSK 3000 --> http://www.vacuubrand.com/us/page794.html
the reason i do not like them is that they are not intuitive and in order to connect more than 2 sensor, is just pain. you have to buy an additional part that can connect. And as far as i understood, you can only see 2 at the same time on your screen (maybe i am wrong on this one).
I researched online and see that there are large number of manufacturer's that claim that their $200 gauge is capable of measuring micron level vacuums with multiple sensors, data logging and so on... Vacuubrand items go for about a $1000, for your reference..
Anyone has any experience with any other vacuum gauges, any suggestions, recommendations, etc... minimum level i would need to measure would be 0.1 mmHg. 0.01 and lower would be nice but not needed. We rarely go to that low range.
thanks in advance
thanks in advance
RE: good vacuum gauge recommendation needed
https://www.mksinst.com/product/product.aspx?ProductID=648
First define your range of concern, and then the accuracy and precision that you need.
I have always had good results with MKS, using many different types of gauges.
@robertib
thank you for the link. this looks pretty promising. The particular item i liked is the 902B with screen, but it seems that it needs outside power supply. Do these come with battery supply at all? I should ask MKS about this info, but since you use MKS instruments already, you may be able to answer to this simple question.
@dicer
yeah, i agree with you, but loading up the rig of that sort into airplane may be a bit difficult. I would need something that is easy transportable
@EdStainless
i need 0.1-1000 torr. As i stated in my original entry, i would be satisfied with this, but having capabilities of measuring deeper vacuum would be great (do not go there that often - maybe once a year, so i could live without it).
All it requires is a USB connection to supply the power - it can be from a computer, or a USB charger similar to the one below.
USB charger
I have last question before i go to MKS for more information. Since it is connected via USB, i assume that there should be a software that could allow you monitoring on computer. Is my assumption correct?
