Force reaction at symmetry plane
I am having some difficulty understanding the force reactions in a symmetry plane.
I am running a half symmetry model, fixed at one end, displacement BC on the other end - it is a two parts assembly - the model is cut in half in the middle and a symmetry BC is placed on the symmetry plane faces, the BCs are all half symmetric (symmetric loading and geometry).
After the solve is done I plot the reaction forces on all BCs (fixed, displacement and symmetry). The fixed reaction and displacement reaction pretty much sums up in the Z direction (the displacement direction - mismatch of about 0.2 N out of 540 N), but there is an added force reaction in the Y direction (normal to the symmetry plane) of about 200 [N]which summs up to a total imbalance of total reactions (fixed BC Vs. Displacement) of about 40 [N].
To my understanding, when I will run a full model anslysis without this symmetry - the imbalance will cancel (I will run it when I get to it, too many projects...) but I am a bit confused regarding the implications of this "imbalance" on the half symmetry model results.
Any input will be much appreciated.
See attched image for a simplified representation of the simulation.
Thanks.
Thanks.
RE: Force reaction at symmetry plane
Thanks for the quick input.
Changing Poisson's ration to 0 didnt change alot (reduced the reaction at the symmetry BC by about 10% but still considerable reaction at the symmetry BC).
