Fluctuating flow
Fluctuating flow
Fluctuating flow (e.g discharge of PD pumps) effects the performance of differential pressure flow meters ? Other type of flowmeter better for measuring pulsating flow ?
John165
RE: Fluctuating flow
A Coriolis meter or a positive displacement meter are most likely better selections. The choice of meter will depend on the accuracy required and the fluid properties.
http://info.smithmeter.com/literature/docs/tp0a014...
John165
I've had good results from turbine meters downstream of duplex and triplex plunger pumps. It seems that the inertia of the rotor tends to average pulse magnitude to some extent. Nothing will make a dP or Coriolis meter give you repeatable or verifiable results downstream of a duplex or triplex plunger pump (although Coriolis meters seem to work well downstream of a quintiplex pump).
David Simpson, PE
MuleShoe Engineering
In questions of science, the authority of a thousand is not worth the humble reasoning of a single individual. Galileo Galilei, Italian Physicist
David Simpson, PE
pd pumps are mostly small liquid pumps
Bimr ! Am not sure , But I think it should be 1 % Full scale.
John165
That works as long as the "chamber" is full every time. I've gotten errors from both neutating disks and turbine meters from flow that was pulsing enough to spin them faster than they could fill. Generally a problem with a discharge to atmosphere through a variable nozzle that was opened too much.
David Simpson, PE
