This testingmotioncallback GTAC revised journal works only on TOP view
Hi
Can someone help in make this journal for peaking rect screen coordinates
and not 3d screen coordinates
Thaniks in advanced
The revised GTAC code
Imports System
Imports NXOpen
Imports NXOpen.UF
Imports NXOpen.UI
Imports NXOpen.Utilities
Module testing_motion_callback_x4_DisplayOgpLine
Public s As Session = Session.GetSession()
Public ufs As UFSession = UFSession.GetUFSession()
Public lw As ListingWindow = s.ListingWindow
Dim screen_pos(2) As Double
dim firsCall As Boolean
Sub Main()
Dim message As String = "Testing Motion Callback"
'Dim screen_pos(2) As Double
Dim viewTag As Tag = s.Parts.Display.Views.WorkView.Tag
Dim response As Integer = 0
Dim motion_cb_data As System.IntPtr
Dim client_data As System.IntPtr = Nothing
ufs.UI.LockUGAccess(ufconstants.UF_UI_FROM_CUSTOM)
firsCall = True
ufs.Ui.SpecifyScreenPosition(message, AddressOf my_motion_cb, _
motion_cb_data, screen_pos, viewTag, response)
firsCall = False
ufs.UI.UnLockUGAccess(ufconstants.UF_UI_FROM_CUSTOM)
End Sub
Public Sub my_motion_cb(ByVal current_pos() As Double, _
ByRef mtn_cb_data As UFUi.MotionCbData, _
ByVal client_data As System.IntPtr)
Dim x0y0() As Double ' = {1, 0, 0}
Dim x1y0() As Double
Dim x0y1() As Double
Dim x1y1() As Double
Dim theView As Tag = mtn_cb_data.view_tag
If firsCall Then
ufs.Disp.DisplayOgpLine(theView, current_pos, current_pos)
Else
x0y0 = screen_pos
x1y0 = { current_pos(0),screen_pos(1),current_pos(2)}
x0y1 = { screen_pos(0),current_pos(1),current_pos(2)}
x1y1 = current_pos
ufs.Disp.DisplayOgpLine(theView, x0y0, x1y0)
ufs.Disp.DisplayOgpLine(theView, x0y0, x0y1)
ufs.Disp.DisplayOgpLine(theView, x1y0, x1y1)
ufs.Disp.DisplayOgpLine(theView, x0y1, x1y1)
End If
End Sub
Public Function GetUnloadOption(ByVal dummy As String) As Integer
Return Session.LibraryUnloadOption.Immediately
End Function
End Module
Thaniks in advanced
Imports System
Imports NXOpen
Imports NXOpen.UF
Imports NXOpen.UI
Sub Main()
firsCall = True
firsCall = False
End Sub
If firsCall Then
Else
x0y0 = screen_pos
x1y1 = current_pos
End If
End Sub
End Function
End Module
