SA-995 grade 6A
SA-995 grade 6A
I work in a valve company. I received a MTR of materials SA-995 grade 6A from a supplier.Chemical composition & mechanical properties conforms with the above materials but PREN value not conform. Should the materials conforms with SA-995 grade 6A.
RE: SA-995 grade 6A
RE: SA-995 grade 6A
Also if you look at SA 995, clause 5.1.6 Additional requirements provides the option of specifying additional requirements such as PREN.
I would suggest, if reporting PREN is mandatory as per the project specifications, then go back to the supplier, with the request for an amended MTR. It may cost you some dollars/euros, but would prevent hassles down the road.
Also I would feel the the content of the following article, though informative could be beneficial..
Thanks.
http://highlandfoundry.com/wp-content/uploads/2015...
Pradip Goswami,P.Eng.IWE
Welding & Metallurgical Specialist
Ontario,Canada.
ca.linkedin.com/pub/pradip-goswami/5/985/299
All provided answer are personal opinions or personal judgements only. It's not connected with any employers by any means.
