What is the bonding mechanism in Soldering and Brazing?
I think this is a pretty basic question but I'm curious about the type of bond that is formed in soldering and brazing processes. Take a tin/lead solder onto copper for example; does a metallurgical bond form between the tin/lead solder alloy and the copper even though the copper is not melted? What type of bond is this? Is this the same type of a bond that forms if the same tin/lead solder alloy were put into contact with a molten copper alloy?
Can a parallel be drawn to cold welding? If two perfectly flat, solid metal bars are brought into contact at room temperature in a vacuum they will bond if the oxide layer is removed from each bonding surface. Is this true for liquid solder bonding to solid copper since the flux removes the oxide layer on both metals and the solder wets out onto the imperfect surface of the solid?
If this theory is true, could a tiny droplet of molten metal in vacuum bond to a much larger solid metal even though the droplet does not have enough thermal energy to melt the solid (assuming it is dropped with enough velocity to properly wet out)?
RE: What is the bonding mechanism in Soldering and Brazing?
you can look the remaining information up yourself.
"...strength equal to or greater than that of the as-brazed parent metal."
We proved this to be true at Metallurgical Consultants Inc. with a tensile test of two stainless steel pieces brazed in hydrogen furnace with nioro braze alloy (Nickel - Gold if memory serves. Failed in parent metal.
Design for RELIABILITY, manufacturability, and maintainability
AWS BH Brazing Handbook
AWS SH Soldering Handbook
Regards, Wil Taylor
o Trust - But Verify!
o Unfortunately, in science what You 'believe' is irrelevant. ["Orion"]
o Learn the rules like a pro, so you can b
