SAP2000 Report Output
Hi Everyone,
My SAP report output shows joint reactions individually calculated for Dead and Live Load. How can I display values calculated for the Load Combos only ?
I have selected the Combos from 'Report Setup' as well as from the Design menu. However, it still shows reactions calculated for individual load cases.
Can someone please help ..
gh
gh
RE: SAP2000 Report Output
The Design menu is not for reporting, it's for specifying which combos you want to include in design code checks.
I agree that selecting load combos from Design menu is not related to the design report.
My issue is that my analysis and design seems to be OK with desired load combos but it shows individual load case evaluation for joint reactions when i create the report.
What I need is to show in the report joint reactions result for the load combos.
Thanks in advance for your help.
GH
