Pipes Penetration in Concrete Beam
Dears,
I have a concrete beam with 200mm width and pipe sleeve of diam 50mm shall go through this beam vertically
- Reinforcement for this beam is 2 dia 16 , so as per code ACI318 i have to achieve cover 40 mm to stirrups and 20 mm to main RFT, for that purpose all my beams in the project shall be increased in width and it is not accepted at all.
anyone have a solution for this case?!!
RE: Pipes Penetration in Concrete Beam
So my advice to you is to find a way around with the installations team, because often it is cheaper to bend a tube than taking special provisions for a perforated beam.
* Anyways here you can find advices and experiences opening (Much bigger beams of course).
MSc. Eng. Serguei Joa
Structural Engineer
Bouygues Batiment International, Cuba.
