Depth of cross-hole
Depth of cross-hole
So I have this blind hole which runs into another through hole.
We are doing root-cause analysis on why a drill went too deep (into the back side of part, almost through) and it wasn't caught.
I observed there was nothing in the inspection plan that required any verification of the depth of the blind hole, to which I was challenged that there was nothing on the print that defined the depth of the hole.
This is interesting to me. We specify prints are to be interpreted per ASME Y14.5-2009, so I went back to that, and couldn't find anything that spoke directly to this situation.
The print calls the hole exactly like the simplified drawing below (i.e. 3.000±.015 typical).
Now, it's my interpretation that the 3.000±.015 dimension controls both the distance from the identified face to centerline of the cross hole and the depth of the blind hole (as marked up below).
However, our quality department seems to disagree with this. They interpret it as only controlling the distance to centerline (just "1" in the mark-up below), and say this dimension does not control the hole depth. When questioned about how they would like the part dimensioned differently to specify hole depth, they don't have an answer, as they agree there's no additional dimension to add (it would just be the same dimension a second time).
So my question is, how would the rest of you interpret it, and how to best define the two requirements? Would you add a hole depth callout?
RE: Depth of cross-hole
Which, btw, I wouldn't consider a blind hole at all. It's a "thru to bore" hole.
Your "typical" is exactly why it's sometimes unwise to use "typical" - I don't think it would apply like you say, at all. The dimension is locating the center-line of the cross hole. That in no way is related to the depth of the intersecting hole - especially when the intersecting boss remains undimensioned. To me, it's an incomplete print. I would never start applying "typical" dimensions as I saw fit until the part was fully defined.
I would call out "Thru to bore" as the hole depth, and possibly (if necessary) a depth-to-centerline dimension as a reference-only. The requirement is that the hole completely intersect the bore and no further. Not that the drill goes to a certain depth (118, 90 or 135 degree drill? Answer: not my problem :) )
Similar to JNieman I'd normally dimension as 'through to XX dia hole' or similar - or if showing the cross section there is an argument you don't even need a depth stated as it's clear from geometry.
Sometimes I'll put a depth with a loose tolerance that ensures a full intersection but I prefer just the above.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
Your drawing has important advantage - the geometry is perfectly clear from the section. Just keep it this way. Also, adding vertical 3.000 dimension wouldn't hurt.
Also (as a splash of kerosene), my impression was that "thru to bore" is supported equally well as "typical". Am I wrong?
Reflecting upon my own intepretation I have to say, I think I was really considering the graphic depiction (section view) to imply the drill was to go to bore and not beyond. I think I was attributing this to the dimension when looking for a way to explain my intepretation, which was wrong, and may have served to further the consternation.
I think I'll suggest changing print to something like this:
The 3X 3.000 isn't very clear what features it applies to.
For features of size, you should normally use position tolerance (unless working in 2009 changed).
At best you can specify the minimum depth a full diameter pin can be inserted in each direction and note that there not be any wall defect/ loss of wall thickness due to processing. It would also be much easier if the intersecting hole was smaller diameter and had a position tolerance smaller than the difference in diameters so that the worst case might be a shared tangency.
