Accessory building without slab
I've been designing a storage building at a residential site for the owner to store a backhoe and tractor along with other items. The building is to be 32'x60'..... basically a large garage. The plans initially called for typical 4' frost walls on an 8x16 strip footing (the frost depth is 4' here, the soil is mostly sand). The walls were to be 2x6's and the roof structure from trusses. The owner told me that he does not want a slab inside the building. He wants stone or "dirt".
In spite of the presence of backfill on the outside of the foundation wall, I'm a bit concerned about the adequacy of 8" poured concrete walls in resisting soil pressure from the equipment inside if it's driven close to the foundation wall. I'd at least spec crushed stone. 'Any suggestions on how to approach evaluating the foundation wall thickness adequacy?
RE: Accessory building without slab
BA
