Stainless steel needle bearings
Hello Folks,
Im looking for ~3/8" and ~ 5/8" stainless steel drawn cup needle bearings with seals but having no luck they can also be in metric if needed.
Thank You So Much
Alec
RE: Stainless steel needle bearings
Don't believe you will find stainless drawn cup needle roller bearing. However, you can try design your own depends on you housing design too.
