Spring Stiffness of Concrete
Hi All,
I am performing a FEM analysis using RISA 3D for the bearing of a plate on a concrete wall. In order to do this I need to figure out what kind of stiffness modulus [units: kip/in^3] to apply to my spring. How would I go about calculating this based on my concrete strength fc'?
RE: Spring Stiffness of Concrete
If you are going to that much trouble, you should calculate the magnitude of foundation settlement too.
BA
