Is there a slimline bulb (lamp)
I'm in need of a slimline bulb for my circuit.
http://catalog.miniscience.com/catalog/electricity...
The bulbs in this link are the type that I seek.
Typically 1.5v but I'm flexible around that.
I require incandescent bulb for heat creation.
Ideally I'd like the bulbs in the link with a significantly reduced base size.
The bulb will be vertically mounted with face down toward the ground.
The bulb will be in close proximity to other circuitry and will have a circuit board directly behind it.
Although I would be open to horizontal mounting, and attaching a heat deflecting housing.
Perhaps this is my only option, if it were vertically mounted I would perhaps require a heat deflector anyway.)
RE: Is there a slimline bulb (lamp)
Have you looked at grain of wheat bulbs?
TTFN (ta ta for now)
FAQ731-376: Eng-Tips.com Forum Policies forum1529: Translation Assistance for Engineers
Thanks they're a good size, I have a few of those around, wasn't sure if they were incandescent.
Wonder how much heat they produce.
