hi buddies.i have one doubt in creo ?
i have some queries on creo please try to solve it.list is given below
1. How to limit the round edges applied on cylindrical shaft, if we select the edge on cylindrical shaft entire edges applied round. (but in square or rectangular box it can be limited)
2. While getting mass properties of created components, it shows the results in Exponential form eg.(xxxxxe-02 kg). how to avoid the exponential form in result.
3. After generating pattern from source instance, patterned instance should be disconnect the link from the Source instance and patterned instance to be edited separately.
4. In Sheet metal, After creating emboss by using forming tool. In future if we edit the used form tool, then it need to be updated on emboss geometry also.
regards,
jaga
regards,
jaga
