Monolithic slab limit
I've been asked to design detached 30x48 residential storage building/garage. I'm considering a monolithic slab for the stick-built structure. Is there any limit to building footprint size in the IBC/ICC that would preclude this? I've seen some local codes limiting building size to 24x24 for this kind of structure, but I can't find any limits in the IBC/ICC. The project is in upstate NY.
RE: Monolithic slab limit
ACI 318 would probably be your best source for slab sizes. I doubt IBC would have any limits on slab size. If your question is if the garage size is too big, check International Residential Code
Nearly all men can stand adversity, but if you want to test a man's character, give him power. Abraham Lincoln
