Roof Gable drag truss with no diagonals
Reviewing a shop drawing for a drag truss that I specified at the gable end. Therefore it has the verticals, but I am accustomed to seeing diagonals as well to transfer the horizontal component, otherwise assuming the verticals as two force members, all the horizontal load has to go through the end connection between top and bottom chord. Or alternatively the truss needs to be properly sheathed.
Is this a common application for a drag truss with no internal diagonals?
RE: Roof Gable drag truss with no diagonals
Just make sure the lateral load gets transferred from roof diaphragm to gable end truss, and from gable end truss to shear wall (in other words, verify the load path).
DaveAtkins
1) You'd need to accomplish 100% of your truss tie down at the heel.
2) The diaphragm shears result in some flexural bending in the truss. No diagonals = little bending resistance.
3) At the heel joint at the upstream end, the plated connection between chords would induce tension perpendicular to grain the bottom chord. It can be done but it don't work real great.
My money says that the truss guys:
a) intend for the gable to be sheathed.
b) don't know what they're talking about.
c) are bullshitting you.
Frankly, I'd place my bet on B. I claim special license to be shitty about these things because I'm an ex-industry insider.
