DISSOLVE/DISPERSE ASSEMBLY
Is there any direct way of make this function? I mean replace a subassembly by all its components in one single click.
This función is called "disperse" in Soliedge and "Dissolve" in Solidworks.
RE: DISSOLVE/DISPERSE ASSEMBLY
www.CADabout.ru
By the way, redefine assembly constraints is a bit annoying because it is not needed in Solidedge (It keeps constraints between two components if you move both from one subassembly to other. I understand each software has its good and bad things but I think this could be a good improvement to future NX releases.
Please do not consider me an ultimate truth, it might be that NX supports the feature you mentioned. I think NX would also keep constraints between two subassembly components, which moved upper, you should test it or wait for another tips.
www.CADabout.ru
Yes, re-constraining is definitely a bother.
"Know the rules well, so you can break them effectively."
-Dalai Lama XIV
www.CADabout.ru
