Exporting as DXF
Exporting as DXF
Greetings,
I am somewhat new to NX, and am working on a prototype project that requires me to export my files as a .dxf so I can import them into our Drag Knife CNC cutting software (Silhouette Studio). My problem arises when I go to import them into the cutting software. The vector lines in my file appear to be scattered, located incorrectly or are missing some lines.
Does anyone have experience exporting files as a .dxf and what settings I should have selected? I know with some other programs that export files as a .dxf the year/revision of the .dxf file can affect the vectors.
I'm also wondering if there is a way to combine the profile lines along with the holes in my design, to make them one entity. Maybe as a way to keep them together during the .dxf export process. I've had luck by using the "Join Curves" command to bring my profile lines together as one. This helps keep those profile lines together during the .dxf export, but the holes in my design are not located properly.
I'm leaning toward the fact that the silhouette Studio software is just not capable of handling .dxf file. (even though they say they do)
But if anyone has any suggestions it would be greatly appreciated
Thanks!
Thanks!
RE: Exporting as DXF
Good Luck
www.nxjournaling.com
