Adhesive for melamin formaldehyde resin and paper plates
Hay!
I am searching a good adhesive which would glue paper impregnated with melamin formaldehyde resin into plateunder high pressure and temperature. Can you suggest one? Thanks in advance!
RE: Adhesive for melamin formaldehyde resin and paper plates
Why not more melamine resin? Epoxy would likely work as well.
I would suggest something we use called Supa Bond.
We manufacture many large kitchen appliances and always use it to seal everything as its solvent free so safe around food.
www.supa-fix.com
Hi , we are also into same trade of manufacturing melamine utensils ...Melamine formaldehyde resins are best to be used to stick the paper ...for offline discussions mail me nitinkohli.ade@gmail.com
