Support-width factor for plywood
Hello All,
I find that the American Plywood Association specifies a support-width factor, equal to 0.25 inch for two-inch nominal lumber framing and 0.625 inch for four-inch nominal lumber framing. I have six-inch nominal lumber framing. Any ideas what support-width factor I should be using?
Thanks!
EIT
RE: Support-width factor for plywood
The support-width factor takes into account that wider supports reduce the clear span. For example, a nominal (center to center) 24" span would have a clear span of 22 1/2" with 2X supports, but a 20 1/2" clear span with 4X supports. In theory, a plywood panel with wider supports is stronger in bending. But, with plywood there are too many other factors that influence strength. 6X supports should be better than either 2X or 4X... but other factors may govern.
The APA tables assume 2X supports for spans less than 48" and 4X supports for spans of 48", or greater. IMHO, for 6X supports just go with the published values.
www.SlideRuleEra.net idea
www.VacuumTubeEra.net r2d2
