Antistatic device pertaining to bronze ball valves
I would like some help pertaining to why or (and) why not anti-static devices are required on bronze ball valves.
RE: Antistatic device pertaining to bronze ball valves
Normally, trunion type ball valves with non-metallic sealings need anti-static device. This is to ensure static charges (which accumulate on the ball) being discharged through metallic connection to the ball via anti-static system.
For better understanding, see "valve selection handbook" by Peter Smith.
Nothing is more fairly distributed than common sense: no one thinks he needs more of it than he already has. Rene Descartes
Hi McDermott1711,
Thanks for the response. I also did go to the referred literature and got the clarification I needed.
