Backing / double sided adhesive tape for EPDM.
Can anyone suggest Backing / double sided adhesive tape for EPDM?
RE: Backing / double sided adhesive tape for EPDM.
A 3M authorized converter will be able to help you with this. Are you sticking EPDM to EPDM, or some other material? Weatherability, environment, etc?
Its for EPDM to metal. Can you suggest a grade?
Research 3M VHB tapes. There are so many varieties. It's impractical for me to suggest a particular variety without knowing the details of the application and its requirements. Your 3M dealer can help you pinpoint the one that will do the best job for you.
