Nonlinear Random Vibration Analysis
I am performing a random vibration analysis in LS Dyna. My model has two parts connected by elastic beams. The overall model is linear, but with the introduction of elastic beam connection, this implies nonlinearity.
As the result, I obtained nonlinear solutions. I'm studying the connection/joints effects on random vibration analysis to understand its limitations in LS Dyna.
My question is that how is it possible for a linear dynamic analysis such as random vibration analysis to have nonlinear solutions? it seems not very intuitive for me that you can start out with a linear analysis and end up with nonlinear solutions. Any comments or elaborations on this would be much appreciated. Any tips from simulation experts (Especially LS Dyna experts) on performing random vibration analysis would be very helpful for me.
Best Regards,
Best Regards,
RE: Nonlinear Random Vibration Analysis
Cheers
Greg Locock
Thank you for your prompt response. I am fully aware that in the real world situation, most of the structures are non linear, and when excited randomly, it would give results. However, I'm not asking from the real life testing point of view.
I will try my best to explain my question better.
Before performing random vibration analysis, we need to perform the modal analysis to obtain the natural frequencies and mode shapes of the system. After that, we use modal superposition method as the basis to perform random vibration analysis. Since random vibration is based on modal superposition method, which requires linear system, random vibration is a dynamic linear analysis.
When nonlinearity is introduced in the system by defining connections, contacts or joints, the random vibration is no longer linear and will give nonlinear results. So then my question is that doesn't the nonlinear random vibration violate the superposition method that it uses as the basis?
I hope I explain myself better. Once again, Thanks for your answer.
So you can't really do a modal on a non linear system, you are really doing an operating deflection shape, and the forcing is part of the analysis set, whereas in a linear modal the forcing is theoretically irrelevant.
Cheers
Greg Locock
