Siemens NX Drafting - Size vs Size2D
In NX Drafting what is the difference between "Size2D" and just "Size" drawing? For ex.: Drawing-A1-Size-template and Drawing-A1-Size2D-template (in UGII\Templates folder).
RE: Siemens NX Drafting - Size vs Size2D
What version of NX are you on ?
The files are the same as far as I recall. The difference is that the Size templates are used when you use File -> New -> Drawing, the Size2D are used when you already have a drawing and you add a new sheet to that drawing file.
Anthony Galante
Senior Support Engineer
NX3 to NX10 with almost every MR (29versions)
NX 10 ... If PhoeNX's answer is valid than thanks!
If I’m not mistaken, X-Size_template is for Master Model Drawings and X-Size2D_template is for Non-MM drawings (Drawing Embedded in Parts).
Michael Fernando (CSWE)
www.solidCADworks.com
Tool and Die Designer
Siemens NX V10.0 + PDW
SWX 2013 SP3.0 X64
PDMWorks 2013
Logopress3
FastForm Advance
FormatWorks
