Nut bearing stress effect on thread force
I would like to find the relationship between the loss in nut material (due to corrosion) and the internal nut thread force. Is there an equation to relate both?
I know the nut area will affect the bearing pressure, but can't develop it further.
Thanks !
RE: Nut bearing stress effect on thread force
Does it cause bending? If not then the load is the same.
