Modeling problem in Compress Codeware
Tom Barsh,
Please Tom Barsh can you hepl me soling this problem,
I am trying to model a chimney which is composed of three parts:
- cylindrical part
- a conical transition which contains stiffening rings
- And a skirt base ring attached to a support skirt
The problem is that i can't attach the skirt to the transition, and i can't replace the transition by a skirt because i can't attach stiffening rings to the skirt.
Can i add a cylinder after the transition to which i attach the skirt ? does this have any effect on the analysis results ?
I really hope you will read my post and answer my question
thank you in advance
